Lenovo Auto Patch Utility - BIOS Password Removal Guide - Indiafix
Lenovo Auto BIOS Patch Utility – Remove Forgotten BIOS Password
Learn how to use Lenovo Auto BIOS Patch Utility to recover forgotten Lenovo BIOS passwords. Step-by-step educational guide for BIOS backup, patch generation, flashing, and restoring original BIOS safely
If you forgot your Lenovo BIOS password and cannot access BIOS settings, the Lenovo Auto BIOS Patch Utility is a commonly discussed method used by technicians for BIOS recovery and testing purposes. This guide explains how the utility works, how to create a patched BIOS file, and the steps required to unlock BIOS access.
What is Lenovo Auto BIOS Patch Utility?
The Lenovo Auto BIOS Patch Utility is a tool designed to modify a BIOS dump file and generate a patched BIOS image. After flashing the patched BIOS, users may temporarily bypass the Supervisor Password screen and regain access to BIOS settings.
This method is widely used by motherboard repair technicians and BIOS engineers for servicing locked Lenovo laptops.
Disclaimer: This article is for educational and authorized repair purposes only. Do not use these methods on devices you do not own or do not have permission to repair. Unauthorized access to protected systems may be illegal.
📋 Utility Specifications
Type 💻 Laptop Unlocker
Brand LENOVO
Model
Thinkpad/ThinkBook
CPU Support 🔵 AMD+Intel
File Size 6MB
👇 Click Below Link To Download Lenovo Auto Patch Utility For Repair
📂 Lenovo Auto Patch Utility
Fix Supervisor Password BIOS access.
⬇️ Click Here to Download Lenovo Auto Patch Utility
🧰 How to Use Lenovo Auto BIOS Patch Utility
Step 1: Generate Patched BIOS
  1. Backup Your Original Lenovo BIOS with BIOS programmer (CH341A, RT809H, EZP2019, etc.).
  2. Drag and drop your original BIOS backup file into the utility.
  3. The tool will automatically generate a patched BIOS file.
⚠️ Lenovo BIOS Password Removal Steps
  • Flash and replace the current BIOS with the generated patched BIOS file.
  • Boot the machine normally.
  • Press Enter, F1, or the required BIOS key to enter BIOS setup.
  • When asked for the Supervisor Password, enter any random character.
  • When the Hardware ID screen appears, press Enter.
  • Press the Space Bar two times when prompted.
  • Turn off the machine completely.
  • Restore the original BIOS backup using your programmer.
  • Power on the laptop and reset BIOS settings to Factory Default.
Proceed only if you know what you’re doing.
💬 Download link not working? Need another Lenovo Auto Patch Utility revision? Leave a comment below and we’ll update the file as soon as possible.
