CP PLUS NVR Firmware Download Free – Latest Firmware for All CP PLUS NVR Series - Indiafix
Download the latest CP PLUS NVR Firmware for free. This guide includes firmware files for CP-UNR 4K Series, AI Face Recognition Series, STQC NVRs, and more. Find your NVR model, download the correct firmware, and update safely.
⚠️ Important Warning Before Updating
This firmware is intended for Authorized Technicians & Installers ONLY.
  • Do NOT attempt this as a DIY project.
  • Incorrect installation may permanently brick your NVR.
  • You may lose all recorded footage and configuration settings.
  • Warranty may become void if the wrong firmware is installed.
How to Update CP PLUS NVR Firmware
Step 1: Identify Your NVR Model
Check the sticker label on your NVR and verify the exact model number.
Step 2: Prepare the USB Drive
  • Use a USB drive between 4GB and 32GB.
  • Format the USB drive to FAT32.
  • Do NOT use NTFS or exFAT.
  • Extract the downloaded firmware ZIP file.
  • Copy the firmware .bin file to the root directory of the USB drive.
Step 3: Upgrade Firmware
  1. Insert the USB drive into the NVR.
  2. Go to System → Upgrade.
  3. Select the firmware file.
  4. Click Start Upgrade.
  5. Wait until the process completes and the NVR reboots.
Step 4: Factory Reset (Mandatory)
After the upgrade:
Settings → System → Maintenance → Factory Default
This step is mandatory to avoid firmware compatibility issues.
Series Supported Models
CP UNR 4K2xxxx V3 & V4 CP-UNR-4K2041-V4, CP-UNR-4K2041-24V3, CP-UNR-4K2041-P4V4, CP-UNR-4K2081-V3, CP-UNR-4K2081-P8V3, CP-UNR-4K2081-V4, CP-UNR-4K2081-PBV4, CP-UNR-4K2161-V3, CP-UNR-4K2163-V4, CP-UNR-4K2042-V3, CP-UNR-4K2042-P4V3, CP-UNR-4K2082-V3, CP-UNR-4K2082-P8V3, CP-UNR-4K2162-P16V3, CP-UNR-4K2162-V3
⬇ Download Firmware
CP UNR 4K4xxxx V3 & V4 CP-UNR-4K4041-V3, CP-UNR-4K4081-V3, CP-UNR-4K4161-V3, CP-UNR-4K4041-P4V3, CP-UNR-4K4083-P4V3, CP-UNR-4K4081-P8V3, CP-UNR-4K4161-PBV3, CP-UNR-4K4041-V4, CP-UNR-4K4085-V4, CP-UNR-4K4161-V4, CP-UNR-4K4042-V4, CP-UNR-4K4082-V4, CP-UNR-4K4162-V4, CP-UNR-4K4322-V4
⬇ Download Firmware
CP-UNR-4K4xxx-FI AI Face Recognition Series CP-UNR-4K4041-FI, CP-UNR-4K4081-FI, CP-UNR-4K4161-FI, CP-UNR-4K4042-FI, CP-UNR-4K4082-FI, CP-UNR-4K4162-FI, CP-UNR-4K4322-FI, CP-UNR-4K4164-FI, CP-UNR-4K4324-FI, CP-UNR-4K4168-FI, CP-UNR-4K4328-FI
⬇ Download Firmware
CP-UNR-4K5xxxx-FI CP-UNR-4K51688-FI, CP-UNR-4K532RB-FI, CP-UNR-4K56488-FI, CP-UNR-4K5082-FI, CP-UNR-4K5162-FI, CP-UNR-4K5322-FI, CP-UNR-4K5164-FI, CP-UNR-4K5324-FI, CP-UNR-4K5644-FI
⬇ Download Firmware
CP-UNR-108F1 CP-UNR-108F1
⬇ Download Firmware
CP Plus STQC Camera NVR (4 & 8 Channel) 4 & 8 Channel NVR Models
⬇ Download Firmware
CP Plus STQC Camera NVR (16 Channel) 16 Channel NVR Models
⬇ Download Firmware
CP Plus STQC Camera NVR (32 Channel) 32 Channel NVR Models
⬇ Download Firmware
CP Plus STQC Camera NVR (64 Channel) 64 Channel NVR Models
⬇ Download Firmware
Conclusion
Keeping your CP PLUS NVR firmware updated improves security, stability, and compatibility with the latest cameras and features. Always verify your model number before downloading and installing firmware. If you are unsure about the update process, contact an authorized CP PLUS technician for assistance.
