How to Change DVR and NVR Serial Number Easily
If you need to change the serial number of a compatible DVR or NVR, DVR Serial Number Changer is a simple and fast solution. This utility is designed for technicians and repair professionals who need to generate a new firmware dump using a valid backup from the same model.
With its one-click operation, the software automatically creates a new dump file after you enter the required serial number.
What Is DVR Serial Number Changer?
DVR Serial Number Changer is a lightweight utility that allows you to create a modified firmware dump with a new serial number. It is easy to use and requires only a valid firmware dump from the same DVR or NVR model.
No advanced technical knowledge is required. The tool automates the process in just a few clicks.
Key Features
- One-click serial number changing utility
- Simple and user-friendly interface
- Automatically generates a new dump file
- Requires only a working dump from the same model
- Fast processing with no complicated settings
- Suitable for many compatible DVR and NVR models
| 📋 Utility Specifications | |
| Utility Name | DVR Serial Number Changer |
| Supported Device | DVR & NVR |
| File Size | 12MB |
| Unsupported Brands | ❌ Hikvision | Prama | HiLook | Skyway DVR |
| Compatibility | Windows 10 / 11 (64-bit) |
🧰 How to Change DVR and NVR Serial Number
Follow these simple steps:
- Open DVR Serial Number Changer.
- Upload a working (OK) dump from the same DVR or NVR model.
- Enter the your and New DVR or NVR serial number.
- Click the Create button.
- The utility automatically generates a new firmware dump with the updated serial number.
- Save the new dump and use it according to your repair or maintenance procedure
⚠️ Unsupported Brands
- Hikvision
- Prama
- HiLook
- Skyway DVR
📂 DVR Serial Number Changer Utility
Fix boot failures & corrupted BIOS with 100% working dump.
Legal Notice
Only use this software on devices you own or are authorized to service. Changing device identifiers without authorization may violate manufacturer policies, local laws, or service agreements.
Always follow ESD safety protocols while handling motherboard components.
💬 Need Help or Different Revision?
If you encounter any issues with the download link or require a different version of the DVR Serial Number Changer Utility, please leave a comment below. We'll assist you promptly and update the file as needed.
